I have the doo rail mounted version with One Rig mounts on my SBA. No issues just hanging them over the bumpers on the rail.
Do you have a ski doo part number for scratchers? Thanks for the pick, it looks like a clean installI have the doo rail mounted version with One Rig mounts on my SBA. No issues just hanging them over the bumpers on the rail. View attachment 2134488
Doo tunnel mount for the assault. Only way to go in my opinion. Reverseable, and replaceable tips. They throw tons of snow. View attachment 2134478
just watched the video with the ski doo with theses installed and now can see how they really work. Excellent video and will likely go this route. I was concerned they where too far back but now see they sprayed the inside of the track well. They mount very nice and deactivate without rail damage. I understand you can replace tips also. Do you recall the ski doo part number? Thanks!Doo tunnel mount for the assault. Only way to go in my opinion. Reverseable, and replaceable tips. They throw tons of snow. View attachment 2134478
Practically a direct swap on the Assault. BRP part #860201516Do you have a ski doo part number for scratchers? Thanks for the pick, it looks like a clean install
Part number 860201728-2Do you have a ski doo part number for scratchers? Thanks for the pick, it looks like a clean install
I replaced my broken Doo spring scratchers with Ibexx last season. I only used them once but they seemed to do the job. Temps came down using them. I don't understand why Ibexx has you mount them with the "spring" wound in the opposite direction of the Ski-Doo spring scratchers? I guess I think that it would create more ground action and pressure, but I wonder if it makes them more susceptible to breaking mounted this way?View attachment 2134501 View attachment 2134503 View attachment 2134504
Ran these last season, worked extremely well until we hit frozen trails. The up had warm weather coming so they were pushing road banks back and anywhere the trail ran along road theyhad huge frozen clumps in trail. These broke springs whether they were up or down. Ibexx replaced springs no problem but if you need them and the break they are not much good.
I used them the season before last and had no issues what so ever and like you temps ran 90’s to low 100’s. We we’re running on extremely hard trail so probably had a lot to do with it. They run coils like that because when you are running in forward direction it is twisting spring into mounts as they are threaded into mounts when installing them. I think if they were mounted opposite they would loosen up.I replaced my broken Doo spring scratchers with Ibexx last season. I only used them once but they seemed to do the job. Temps came down using them. I don't understand why Ibexx has you mount them with the "spring" wound in the opposite direction of the Ski-Doo spring scratchers? I guess I think that it would create more ground action and pressure, but I wonder if it makes them more susceptible to breaking mounted this way?
These are long version. As you can see in picture I used ibexx mount so I can quickly swap out if not happy. Still have ibexx on 21 as they worked very well the first season on 21.Are those short or long version?
I tried short ones last year and that heavy tip will destroy your rails in short order!
Keep close eye on them!
These seem to deploy when driven "inspired" without wanting it. On smooth trails, no problem, but when trails are bad and an occasional jump they do not stay in place. It's the edge of the track that forces them up I think. Thats my experience with them.View attachment 2134505
Going to try these next season. Going to mount P clamp to rail for storage.
I have even had ibexx do that so no biggie. Like I said I am going to put a P clamp on rail for storage. They fit tight in the clamp so hopefully the stay put?These seem to deploy when driven "inspired" without wanting it. On smooth trails, no problem, but when trails are bad and an occasional jump they do not stay in place. It's the edge of the track that forces them up I think. Thats my experience with them.
Agreed, even the rail mount spring style scratchers will self deploy if you hit a rut or something solid on the side of a trail. Not a perfect world when travelling by snow machine on hard pan conditions.These seem to deploy when driven "inspired" without wanting it. On smooth trails, no problem, but when trails are bad and an occasional jump they do not stay in place. It's the edge of the track that forces them up I think. Thats my experience with them.
