I see on here that there is one case of the clutch having a problem, that looked like it cracked on the back sheave, other than that, that's the only guy that had a problem with the p-22, no bolts breaking, or any other problems?
What the offset? Also, is there a rebuild kit for the p22 yet??The P22 weights are very wide at the pin. That added weight does not contribute to squeezing the belt.
Offset is the same as with P-85 if using the factory alignment bar.What the offset? Also, is there a rebuild kit for the p22 yet??
