Hi just wondering what kind of speed you guys are getting on you 98,99,2000, xc 700. I know that the speedo is off but just wondering what they should roughly hit on the speedo.,,,,,,,,thanks
I can get about 112 mph on the dreamometer on the 600. My guess with the 700, you would be looking close to 120 mph.Hi just wondering what kind of speed you guys are getting on you 98,99,2000, xc 700. I know that the speedo is off but just wondering what they should roughly hit on the speedo.,,,,,,,,thanks[/b]
my 98 with psi pipes and hot seat heads speed tack with 192 chisels has went 115 on ice and i wiegh 280 . stock they run 107 this is in 2000ftI agree with all the above posts also, speedo is usually 8-10 mph off, my 98 with 25/40 gearing and the mods that I have has pulled 117 in the quarter mile on asphalt.[/b]
mine is a 700 it has psi twinn pipes ,rad valves,hotseat head,and light porting.112 on the 98 XC 6? I'm curious of how you have yours set-up? What distance? I've seen maybe 105 in 3/4 mile.[/b]
I have no idea what has been done to the sled. I bought it 3 years ago. The person I bought it from said some work had been done to it by the previoous owner, but I didn't get the details. It doesn't matter to me. The sled is used for mainly trail riding and now my son is using it. I had the first opportunity to run it wide open this year on a lake in early winter, about 2" of powder and a pretty long run netted the 112 mph on the speedo.112 on the 98 XC 6? I'm curious of how you have yours set-up? What distance? I've seen maybe 105 in 3/4 mile.[/b]
I had a '98 XC 600 that was completely stock except for 120 studs. The sled would hit 104 mph (radar) consistently in 2000' if the air temps were cold and the ice was good. The speedo showed 110, so it was off by 6 mph. A friend of the family had a '98 XC 600, and his also hit 104 (radar).112 on the 98 XC 6? I'm curious of how you have yours set-up? What distance? I've seen maybe 105 in 3/4 mile.[/b]
Its an old sled so most likely your clutch parts are worn, and it also depends on your jetting. Compression needs to be good.my 99 xc700 only hits 105 on the speedo. whats wrong[/b]
