Can anyone tell me what this is? Line attached goes to a block which is connected to the fuel pump. It appears maybe vacuum.
Interesting you mentioned the turbo V-Max 4.
The fastest I have ever gone on a sled thru radar, was on one of those sleds owned by a guy from Alexandria Bay in New York . I went past the gun @ 134.5 miles per hour way back in 1992, and then a friend of mine who was a bit lighter went thru @ 134.9.
Amazing those speeds could be reached way back then.
Out of curiosity, do you re-phase the crank on that sled you put the turbo on ?
The VMax 4 800 turbo sled used a too small Aerocharger series 53 143/300 turbo. It was the largest Aerocharger available at that time. Maximum hp available was around 210 hp. I used a earlier larger turbo model 60, 199/250 on most of my VMax 4 turbo builds. And on all my Polaris 750/800 Storm and T-Cat 900 turbo builds. Capable of around 250 hp+. Much faster due to less backpressure. Later, a model 66 Aerocharger became available. Capable of around 350 hp on a T-Cat, 325 on a Skidoo or Storm/XCR 800.This sled was just given to me, so I am still finding out all what has been done to. I did pull the plugs and the firing order is not what was original from the manufacturer. The crank appears to have been spun 180 on this sled. I have heard both ways even installing a turbo. Patroticinnovations , I'm sure can answer this way better then me.
