I went to take secondary clutch off remove the bolt give a liitle tug and nothing wtf.Any one have any tricks to removing them when they are stuck. It is a splined shaft and never had problems removing it any other year.
That seems odd as there is only 1 bolt holding it on. I'd hit it with a rubber mallet a few times. Maybe lift it up, remove the air box and move the track so you can hit all the way around it.
The bolt comes off no problem it is just the clutch that seems frozen on the spline shaft.When you get it off might as well buy a new bolt- cheap but it may bend if it's that stubborn! I agree- no hammer! It will come off!
With a Polaris button clutch,,remove the adjuster plate from the clutch,find 3 longer bolts to go in the plate holes and use a crows foot puller to remove the clutch:thumbsup:I can't get mine off. 700xc. I know on the trail last year the bolt backed out and I could not find the big metal circle thing with the hole in the middle so I had to pound the key back into the slot as best I could it was not deep enough to allow the round metal thing anywhere near back into the space it is supposed to hold.
I can NOT now get that damn secondary off. pb blaster last night hope it will slide off tomorrow but I likely doubt it. Can not believe how tight it is can't even budge it. I am sure it has to do with the damn key I pounded into the shaft but on the trail we do all sorts of bad stuff to keep going. Any other suggestions. I will likely have to pull the air box to have at it.
hint of danger,,,,,,I like it:thumbsup::buttrock:I would try running it and hit the brake a couple of times. That should free it up.
You're right.hint of danger,,,,,,I like it:thumbsup::buttrock:
