What I did is mimick what would happen to the skis as far as ride hieght with different skids. This will give ideas on ski pressure and ski lift.
The edge skid is pictured here. With the rear sissor touching the front sissor stop gave me a dimension, then when touching the rear sissor stop. The dimension is given between the bench and a point 64 inches forward of the rear bolt location in the tunnel, aproximatlly the center line of the ski bolt.
what I have determined is in stock locations the edge and prox are similar.
The relocation mod definatlly raises the front end and causes ski lift.
My Idea of using edge torque links, which got rid of sag, will lift the skis to the moon and can't be used.
These are the dimensions of different things I tried
[attachment=641921:009.JPG]
This is a pick of the rear sissor touching the fss
[attachment=641918:001.JPG]
This is a pic of the rear sissor touching the rss
This will give you a idea of what happens with different rss locations.
