I see on here that there is one case of the clutch having a problem, that looked like it cracked on the back sheave, other than that, that's the only guy that had a problem with the p-22, no bolts breaking, or any other problems?
The weights used in a stock P-22 and the geometry of roller location vs weight pivot points vs the P-85 are different so I've been told. It isn't just a simple weight to weight comparison.Hmmm… p22 with 2 choices of belts, one narrower but the same length as a standard p85 belt that we can all agree performs bad. Or the 23 Boost belt that is the same width as a standard p85 belt but is longer.
Does the longer 23 Boost belt with a p22 have the same top speed potential as a p85 with the standard belt? How can it if the engine is placed in the correct location?
Fact is given the belt choices we have with both clutches, (this includes the wider/softer CC p85 belt) the p85 will always have an advantage in either starting ratio and or top speed.
We should discuss why the p22 requires so much weight to perform the same job as a p85.
I think that’s is Battlestorm s point, those design changes in the P-22 requires more weight to achieve what the most efficient primary (p-85) used to do. That extra weight is stress and if combined with imbalances and or spider design, bolt materials have probably lead to some early failures. Then they added a scatter shield and for most, the good feeling is gone. The P-22 is not going away and the P-85 probably is. This is no different than changing computer operating systems, the last one before the latest change is always better than the new one, until you figure out how to use the new one.The weights used in a stock P-22 and the geometry of roller location vs weight pivot points vs the P-85 are different so I've been told. It isn't just a simple weight to weight comparison.
really? how how have they done with the forward twist? they haven't fixed that in what 7 years now.Amazing that the "savvy tuners" have opposing info. The bottom line is that the P-85 is going away and the P-22 is replacing it because it has better advantages. The factory will eventually make the improvements needed in the P-22 to ensure it is safe. They don't want lawsuits and high warranty costs.
The excessive forward twist apparently isn't seen by them as a big negative. Mainly because the competition is at least as bad. And don't even float their 2ndy. I bet I could advertise a service fixing only that issue and make a fortune.really? how how have they done with the forward twist? they haven't fixed that in what 7 years now.
You advertise in almost every post you makeThe excessive forward twist apparently isn't seen by them as a big negative. Mainly because the competition is at least as bad. And don't even float their 2ndy. I bet I could advertise a service fixing only that issue and make a fortune.
But some of us know how stupid it is. Belt wear savings alone, as well as less jackshaft bearing wear would easily pay for it. Not to mention better mileage and power to the track. TSR is likely already doing it. I do it much cheaper though. The customer can easily do it themselves. But, if they won't, then will have to complain enough to make them fix it.
I explain what I know by providing the same details I expect from others. I say certain supporting things so I help folks to understand. How do you do it? Just state your opinion with no logical reason why? This also helps prevent misinformation by novices. I hope this statement doesn't apply to you. I'm offering free information unlike many on here who make a living generating work for themselves. Some folks appreciate it, others don't. Does being upfront with valuable free information offend you?You advertise in almost every post you make![]()
What happened that it's a amazing clutch with no issues? And it's superior with its easy ability to make changes? It's the best thing ever with no belt deflection needed? It's been better but still a ticking time bombAmazing that the "savvy tuners" have opposing info. The bottom line is that the P-85 is going away and the P-22 is replacing it because it has better advantages. The factory will eventually make the improvements needed in the P-22 to ensure it is safe. They don't want lawsuits and high warranty costs.
Thanks. I also respect capability. And know how important field testing is.What happened that it's a amazing clutch with no issues? And it's superior with its easy ability to make changes? It's the best thing ever with no belt deflection needed? It's been better but still a ticking time bomb
I've been busting your balls but I do respect you. You're pretty sharp but need to understand that are a few people around here that are too . I test a ton. Put alot of miles on. Of all people you should understand field testing is beyond solid. I won't put a P22 on my sled. I still flat out tell you the P85 grabs the belt way harder. I might not be a "savvy" tuner but I'll still show you different in the field.
Phil you guys pretty much have me talked into doing this adjustment using the trs mounts. I wasn’t concerned at first but for a few bucks and some time I guess I’ll address it. But I have one question that I’m sure isn’t totally cut and dry but maybe you can provide a lil insight. Question is - do you think that lining up the engine and leaving 20thous or so of lead in will account for enough engine movement when a boost is turned up wayyyy beyond 200dyno hp. And loading the clutches / grabbing the belt harder and having good traction ? Or should I leave a lil extra say 30thous. ? And only aligned to remove any beyond that. Or should I still get it closer as most of the time it will see trail riding on a pump gas tune so 210 or lessThe excessive forward twist apparently isn't seen by them as a big negative. Mainly because the competition is at least as bad. And don't even float their 2ndy. I bet I could advertise a service fixing only that issue and make a fortune.
Well Lid, I maintain that the engine mounts used by Polaris on their 850 sleds does not allow enough rearward twist under load that would justify so much forward twist. This assessment was also reached by TRS out West when they developed their adjustable engine mounts. If you watch one of their videos they posted online, they never say to add more forward twist than around .020".Phil you guys pretty much have me talked into doing this adjustment using the trs mounts. I wasn’t concerned at first but for a few bucks and some time I guess I’ll address it. But I have one question that I’m sure isn’t totally cut and dry but maybe you can provide a lil insight. Question is - do you think that lining up the engine and leaving 20thous or so of lead in will account for enough engine movement when a boost is turned up wayyyy beyond 200dyno hp. And loading the clutches / grabbing the belt harder and having good traction ? Or should I leave a lil extra say 30thous. ? And only aligned to remove any beyond that. Or should I still get it closer as most of the time it will see trail riding on a pump gas tune so 210 or less
So to be clear IF i didn’t use the aftermarket mounts I could just take a measurement of what it would take to get the lead in to 20thous. Then slot the LEFT rear mount that amount or a touch more. And then shim the LEFT front mount to chassis connection the same amount needed for 20thous.. and then just loosen the RIGHT side mounts to allow the movement . Then lock it all down and varify the 20thous. Is still achieved ? Does this sum it up ?Well Lid, I maintain that the engine mounts used by Polaris on their 850 sleds does not allow enough reward twist under load that would justify so much forward twist. This assessment was also reached by TRS out West when they developed their adjustable engine mounts. If you watch one of their videos they posted online, they never say to add more forward twist than around .020".
I agree. And the famous Aaen states as much in his clutching manual. Yes, as one of the resident experts just stated, Aaen is dead. But he was a great engineer when he was alive. I also do not use those expensive adjustable mounts. Instead, I just "untwist" the engine by slotting the left rear engine mount bracket about .060 and adding a .060 washer between the left front mount and the frame. The exact amount depends on how far the engine is twisted too much. This is much cheaper and just as effective. I've done it to many 850 Polaris engines. NA and Boost. The 9r is likely just as bad.
Keep in mind some of the clutch issues are probably created by the owners or shops not using proper diligence during service and installation of clutch and parts to include proper torque and retorque . I’m not a huge p22 fan. But l think some of this is end user . I personally would not use the aftermarket “lock” that require gallons of locktite. Just my opinionSee there was issues/changes to the mounting bolt on the P22. Now there is no less then 4 aftermarket companies making a product to lock the spider on simular to the jam nut on the P85. I'd be running something to lock the spider in place on the P22.
