IDD Says: "Change oil"-- pictures added
23K views 12 replies 11 participants last post by  masacheez
#1 ·
Don't have the manual handy and I'm up North. What is this about?
#7 ·
I believe the reset option is only available with the engine running. Just like the running hours...
#9 ·
Some pics to hopefully help folks out.
Press the center button to get your options up, and arrow down to the "System Settings"
Scroll to the "Service" option:
This is what it looks like if your engine isn't running:
This is what it looks like with engine running - notice the reset option in the lower right:
After pressing the button to select "Reset" you can choose to change the service interval, or turn it off altogether (which is what I selected):
Press the button to confirm, and exit back to your display.
#12 ·
After pressing the Reset button 5, you will see...
The Reset fuction is intended to reset or zero out the Hours to (next) Service hours counter. BUT it also allows you to change the time interval before the next reminder You can even turn OFF the reminders.
When the grey "Reset Service Hours?" box is being displayed, you can press button 2 or button 4. (Down or Up arrows) to scroll thru the Service Interval choices:
OFF, 5, 10, 15, ... 100
Press center button 3 to confirm your choice, and return to your display.
NOTE:
I had a mental block on this step, probably due to the 10 years that I used the IQ Digital display.
#13 ·
Your PIDD may "think" it's installed in a UTV
I realize this thread is old but I just experienced an issue after updating my maps in which my PIDD displayed 4WD, seat belt and oil change indicators as well as showing I had an audio system.
To remedy this you must "initialize" the screen if it does not do it on it's own. You do this through the "system settings". I personally experienced a time in which I had to do it twice (Not sure if I did something incorrectly the first time though). After the second initialize, my seld no longer "thought" it was a UTV. :buttrock:
