I have a 05 f7 with a 800 kit in it I'm having a issue with it idling to low with the choke on when first starting . I have 135 starter jets in it if I go up 1 size will that raise my idle at cold starts at all ?
Idles Too low as in rich and dull sounding and gets worse as it warms up. OR.....too low as in sounds crisp and tinny, then bogs out, but will idle better with the choke on as it warms up?
try it with the choke off after a start , they all will tend to load up with the choke on , is this a new sled to u? I full choke mine, after it starts, i turn the choke off, if by chance it trys to stall i flip the choke half way for a sec or two,you dont really want to run it cold with the choke on .it will fuel foul the plugs
I do the same thing with the choke but it barely idles . It idles low enough that none of the gauges or lights work . What does yours idle at ? Is there any way to bump the idle speed up at all ?
Doing that will make the choke not open as far right . When I took the carbs off I noticed that the choke plungers are not being pulled all the way up. Should I put more slack in the cable or should I adjust the cable so the plungers get pulled all the way up ?
