Think of this, your exhaust temp coming out of the motor is around 1200 degrees right, look at these pictures of where all the heat comes from under the hood.
pipes uncovered, muffler shield not blocking enough heat from mounting brackets on stock mufflers and many other mufflers your buying have no heat shields right.
Oil lines are right close to the stock muffler brackets on the bottom, that is not very good, it is heating up oil in the aluminum tubes being feed to the motor.
There is only and only one way to get most of this heat out= venting the side panel on the muffler side will help but is not the total fix, when you are at a gas station or road crossings and such and not moving fast, the heat keeps heating up the clutches and belt, then when you get a cross the roads, the first thing you do is wot. the belt is to hot by then, either you have to go slow then pick up speed so the vents can do there real job by cooling the clutches and belt off.
either you have to cover all these parts in these pictures of naked pipes and seal off the mounting brackets with silicone and such.
stage 1 option kit will be made to cover all these pipes.
stage 2 option kit would be to install a 12 volt fan behind the vent that i am showing you with a pointer where to install it, these kits will be for sale soon.
I have tested all temps on both the 4 stroke NA's and turboed sleds and the 800's, its way to hot under these hoods for any belt to last very long if running them like you stole it and going slow is to much of a problem also, these are great sleds cat gave us an with a little fine tuning you get more bang for you buck and less belt problems.
By the way, the flex pipe is hitting the cross member behind it, check it out, this sled has 500 miles on it.
I know how hot it takes to melt wire loom== i had some over my y pipe on my 800 and it melted it an it never touched it, it was 4" away and melted
Catf1000s/p
Frank
Catf1000s/p
Frank
