My brother is looking at a 23 boost. Are the 23s okay?? Anything to look for or stay away from?
Possibly in break in mode before ?Any one indexing there plugs, I have found a much nicer burn. Also plugs with the reed valve had dark burn insulators with some crust around the bottom of the grd electrode and base edge ,lots of smoke on warm up and the red cold warning would disappear at 76F now with the TRS I have light tan insulator cleaner looking plugs possible to the lean side, very little smoke on warm up and red cold engine bar goes off at 61F.
I wiped the inside of the air box and cloth came out clean, no oil in any lower conner found. Big difference is my plug insulators were chocolate brown ie coffee with 1/2 a cream and know (new plugs) are light tan color with TRS.pretty much what has happened to mine after switching to the copycat brp-trs valve. my factory valve was perfect, I did have a lot of oil in air box did you?
shouldn't be as it had over 4500 when I added the TRS.Possibly in break in mode before ?
All the Trs valve is doing is sealing the boost box so your drawing outside cold air under boost .shouldn't be as it had over 4500 when I added the TRS.
I do have a ? for you, when you update the 23 to the 24/25 ECU does this improve high end rpm engine run ability?I am not aware of anything that changes the temperature at which the red cold engine bar goes off.
I'd recommend that you start a thread in an appropriate forum, and include the exact model of snowmobile having this problem.need help identifying two new codes spn 523953 fmi 5 and 523949 fmi 7
Not sure about 523953 fmi 5 but possibly start with a wastegate relearn and go from there.need help identifying two new codes spn 523953 fmi 5 and 523949 fmi 7
Yes, but it also allows the airbox to draw atmospheric air directly without the restriction of the turbo compressor when it hasn't spooled up enough to make boost.All the Trs valve is doing is sealing the boost box so your drawing outside cold air under boost .
I did both relearns and something isn't right, after a perfect 91 mile ride , it never had it's 2200 plus strong idle and sounds like its running on 1 1/2 sparkplug's , valves used to open at 6000 now 6700. worked perfect after cleaning but did have a strange hangup up a couple times when testing on the bench. put it all together with new plugs worked great until ride home. Still screams past 6700 to 8200. it did have a hunting rpm from 4200 to4500, almost like bouncing off a rev limiter good at 4000 rpm and good after 4600 rpm. seems like tps. dash never showed any codes found them with my slp tuner. Someone else mentioned the same rpm thing in the same range I wonder if they figured it outNot sure about 523953 fmi 5 but possibly start with a wastegate relearn and go from there.
Make sure your voltage is above 12.6 volts or the relearns may not take , also when doing relearns make sure sled is up to operating temp .I did both relearns and something isn't right, after a perfect 91 mile ride , it never had it's 2200 plus strong idle and sounds like its running on 1 1/2 sparkplug's , valves used to open at 6000 now 6700. worked perfect after cleaning but did have a strange hangup up a couple times when testing on the bench. put it all together with new plugs worked great until ride home. Still screams past 6700 to 8200. it did have a hunting rpm from 4200 to4500, almost like bouncing off a rev limiter good at 4000 rpm and good after 4600 rpm. seems like tps. dash never showed any codes found them with my slp tuner. Someone else mentioned the same rpm thing in the same range I wonder if they figured it out
I was 12.8 on the battery but sled was only room temperatureMake sure your voltage is above 12.6 volts or the relearns may not take , also when doing relearns make sure sled is up to operating temp .
04prox2 code523949 fmi 7-is for boost actuator learn ck failure, this is the EcU detecting wastegate position voltage and fault is issued if the open or closed position is to far out of range. I expect will need the Polaris DW.
no nothing off all original but going to have to deal with the bad reeds first..man these are put together like shit. found multiple chaffed wire harnessesDid you have the actuator off recently o4? You can install it wrong and get those codes. I didn’t know how I know this. Lol
Br9eya at .20-.22 gap on plugs have worked well for me
this is the new polaris. gone backwards.no nothing off all original but going to have to deal with the bad reeds first..man these are put together like shit. found multiple chaffed wire harnesses View attachment 2167222 View attachment 2167223
