1998 670 summit x...specs/ what to expect??
24K views 4 replies 4 participants last post by  Zombiehunter
#1 ·
Hey everyone. I was curious if someone could give me some info on the 98 670 summit x. It has DPM, something I did not have on my 95. Also if you can tell me HP and what these sleds preform like, that would be great.
I'm thinking about picking one up with 3000 original Kms on it. It has 135 lbs of compression in each cylinder and all stock, nothing tampered with. It's had a easy life by the sounds of it. What would be a reasonable price for this sled?
Thanks in advance for your thoughts
Nate
#5 ·
the 98 summit 670 is the same motor found in the 99 ho, they are different from the standard 670 in having a different ignition, porting, rotary valve, pipe, and compression. the motor was a work of art and the swan song of rotary development. they made 128 to 131 hp depending whos dyno they were on. power was a little peaky, you could feel it "come on the pipe and it wanted to pull your arms off. great torque. at the time it made as much hp as 800 twins and was considered a grass drag beast.
I had #247 of 400 toni hiekonnen edition mxz 670 ho, wish i still had it!
:buttrock:
