1 - 7 of 7 Posts
Hi Guys,
Had a driveshaft failure that snapped off in the chain case of my 1997 zrt600. The reverse gear is really chewed up. What do I have to remove reverse from that sled? Just remove the gears that were added, different length chain? Any help would be appreciated!
Thanks
Get the stck gears, its 23top and 40 bottom and a new chain. Im not sure if they use the same top sprocket with the reverse or not, but if it is all you need is the bottom and a new chain. take out all the reverse stuff and you might need a manual adjuster. Or you can leave the self adjusting adjuster.
I ditched reverse on mine and went with 20/39 gears and a roller cover off a 97 (I think) ZR 440. I love the lower ratio, and mine actually goes fast with the lower gears and my setup.
You will just have to monkey with the stud where the idler is attached, mine broke off so I just plugged it, and put silicone on top of it.
The second pic is from someone on this site I believe, I wish I could give credit.
My pic is the one with the orange silicone.
Thanks for the reply guys. Basically I'm looking for the cheapest way out. How much do you think it will cost to get the stock gears? Prob cheaper than that reverse gear, lol
I got my gears used at a salvage yard. You will need a regular cover and I would recommend a new chain.
You could just get a regular bottom gear and throw it in if you want.
I got a new chain because I dropped from a 72 to a 70
Check e-bay. item #4576893301. You can e-mail the guy, he's probablly got what you need..
Would you want to sell everything you have as a set with the dammaged gears? Maybe trade for a chaincase with gears that is complete and working fine out of a zrt?
1 - 7 of 7 Posts
