the middle pipe on my 96 zrt 600 the center pipe has a rattle to it . is there anything inside it , baffles,plates ? I dont want to just start cutting on it . tia Mark
pipes are completely hollow. the can has baffels. did you take pipe off yet? bet you'll find your friendly mouse/chipmunk left a few nuts there for later. or worse yet a chunk of broken pistons skirt. it's been a long time, but i think theres a support bracket for the bottom of the center pipe that mite be loose.
yes ,I had it off ,hit it and it sounds like a piece of loose (yet held in place by something )sheetmetal in there .no mice or rodents of any kind ,nor is it the piston skirt but thanks for trying ! when I hit the pipe with my hand there is a reverberation inside, just not a loose piece .might just have to do some exploratory surgery as the noise it makes is intollerable :dunno:
I cut a section out of my buds 1997 ZRT 600 sled last winter for the same reason.There is another thin piece of metal in the pipe that has come loose.I used a cut off tool with a fine blade and cut a section out of the under side of his pipe and migged the section back in after tacking the loose piece first.
yes ,I had it off ,hit it and it sounds like a piece of loose (yet held in place by something )sheetmetal in there .no mice or rodents of any kind ,nor is it the piston skirt but thanks for trying ! when I hit the pipe with my hand there is a reverberation inside, just not a loose piece .might just have to do some exploratory surgery as the noise it makes is intollerable :dunno:[/b]
Do any of your mechanic friends or electricians have a bore scope that you could use? I have one but I am sure you are a ways a way. Saves you frome cutting up a pipe.
well I cut some holes in it with the matabo , secured the loose inner piece and tacked it in quite a few places then welded the pipe back up . no more rattles . thanks all for the help :thumbsup:
