1 - 9 of 9 Posts
Sorry if it's a repost but I've never seen anyone with this set up.
Ideally I think it would be neat to see a triple/triple 600 or 800 in a ZR chassis.
Anyone?
I think it would be a tight fit to get the triple in, but anything is possible with some work,like to see it though.
Basically you are only making a ZRT triple in a different hood and belly pan. Short of a noth in the front of the frame for the pipes to clear, they are an identical Chassis geometry and mountings. There is no difference.
It's my understanding they are two totally different chassis. I know engine weight is a large factor but I've ridden a '99 ZRT 6 and an '02 ZR 500 back to back and I LOVE the handling of the ZR much more. I was certain it was more than just the plastics.
If you put a ZRT engine in that 500 ZR chassis it will handle like a ZRT. It's the weight of the engine that makes it handle differently.
there is a 98 zr for sale on e-bay that was supposedly from black magic racing and a special they built with a zrt 600 mill.........sled still set up for a triple but the motor is gone..............i agree that the weight difference is the biggest difference in handling but pulling up to someone on an all green zr and shocking them with the grunt of a well tuned triple would be cool.........then again a 1000 triple pantera with a panther hood :augen41:
yes the zr chassis will take the tripple even a 1000 the bulkhead is already marked for the mounts they just have to be drilled out.need to get different pipes though jaws makes a set for the conversion.
Saw a 1000 tripple in a 440 snopro zr chassis last year..ran pretty good. Not worth the trouble if you ask me.
1 - 9 of 9 Posts
