1 - 10 of 10 Posts
Code 11: Cylinder identification sensor or circuit problem.
Code 12: Crankshaft sensor or circuit problem
Code 13: Intake pressure sensor or circuit problem on Cylinder #1.
Code 25: Intake pressure sensor or circuit problem on Cylinder #2.
Code 14: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #1.
Code 26: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #2.
Code 15: Throttle position sensor or circuit problem.
Code 16: Throttle position sensor is not moving.
Code 21: Coolant temp sensor or circuit problem.
Code 22: Intake temp sensor or circuit problem.
Code 30: Oil pressure sensor or circuit senses low engine oil pressure. ECU turns off main relay and stops engine.
Code 33: Open circuit in the primary circuit of the Cylidner #1 ignition coil.
Code 34: Open circuit in the primary circuit of the Cylinder #2 ignition coil.
Code 42: Speed sensor or circuit problem.
Code 43: ECU unable to monitor system voltage due to an open or short circuit in fuel system circuit.
Code 44: Internal ECU problem with CO setting or adjustment mode.
Code 46: System voltage is too high or too low.
Code 50: ECU internal memory or data problem.
Code 65: Knock sensor or circuit problem.
Code 81: Grip warmer open or short circuit.
Code 83: Thum warmer open or short circuit.
Code 84: TORS system has been activated.
Code 85: Short or open circuit in oil pressure switch.
Code 88: Short or open circuit in reverse indicator switch.
2007 Phazer Error Code
I have a 2007 Fuel Ignition System error code as well as a blinking caution light. The sled will not turn over. It won't do anything. The fuel pump does not even come on to prime. I cannot figure out the problem. Can anyone help.
Thanks
Mt. Shasta
Did oil change code 26 now checked the hoses all to the airbox like it says all are fine had it off and on 3 times now and the code won't clear ? Anyone
Got code 22 while on trip this past week end. It starts and runs fine with the exception of some back fireing every now and then. Any thoughts on this? Thanks.
I have a 2009 phazer mtx, this past weekend had a stalling problem. Engine code 34 came up. The company I bought it from included a warranty with the sled, and ordered a new coil. Turns out my coil was not the problem, it was the plug that comes from the harness at the coil, they replaced the plug, runs good now. Just thought I would share. Ride safe!
Indy XC 137 800
Thanks
Mt. Shasta
Check all your ground blocks...07's were bad for corrosion and burnt blocks.
1 - 10 of 10 Posts
