Mine F5 doesn't start good either when warm. Takes some throttleOriginally posted by f5sweden@Jan 14 2003, 10:16 PM
You got to give my F5 some trotle when it's warm otherwise it whon't start!?
What could be wrong?
I think the sleed should start right up when it's warm!
Wronggggg. :blink: :blink: :blink:Originally posted by northeaster@Jan 16 2003, 10:56 PM
Adjust the choke plungers down a little.
The main jet circuit does not come into play when starting engine.Originally posted by SNODOGG@Jan 17 2003, 04:08 PM
TOO MUCH FUEL, JET IT DOWN 1 OR I WENT 2.....SEEMS TO START RIGHT UP AND IDLE GOOD THIS TIME. THINK OF IT AS HAVING TO LET MORE AIR IN AT THE CARBS <_<
Yes, I have experience with mikuni carbs, holley carbs, rochester carbs also. The reason I said wrong is because I've checked all settings and the plungers were set correctly and the issue still existed. No offense was intended.Originally posted by northeaster@Jan 17 2003, 06:47 PM
Gunner why do you say "wrong" sometimes the plungers are too high and with the choke off its still being choked slightly ,dropping them closes the orfice off when the chokes off.Have you ever worked on carbs?Atleast thats the way it works on mukuni round slides.
