Hey Guys,
Pulled my 1998 ZL 440 out of the shed today, after having it sit there for 2 years, properly stored. Was going to fire it up and take some pictures of it, so that I could put it one the market, as this sled is mint. WELL , guess what ? It will NOT start !! It has NO SPARK.
This sled was completely gone through by the local Cat dealer two years ago and it ran fine before I put it in storage in my shed. Now it will not even fire. No spark at all on the plugs.
Any ideas on what is wrong ?
1st change your plugs, see if that works
Coil could be gone but if your head light will not even light up for a second when you try and start it, it could be your voltage regualtor or you stator.
Sled has brand new plugs that were installed when the sled was tuned, two years ago. But even then, I changed the plugs and still no effect, still no spark.
Not sure if headlight will light when pulling it over, as I was alone. Will probably have my wife check the headlight the next time that I try pulling it over.
From what I have read, I am really thinking it is the stator. But, I just can not figure out how a stator goes bad on a sled that is in storage.
Thanks for your input on this matter.
i had this probley with my z idk if it the same thing but theres a lil fuse up aginst the fire wall near ur chain case its in a lil black cover idk if its it but worth checking
Thanks for your input on this matter.[/b]
Tail light should light up too, or open the hood and you should be able to see the headlight glow a little when you pull it over, if neither lights up, voltage reg. is probably shot.
OR
Check your kill switches and ignition switch, i had one go bad on an older sled after just sitting a couple years.
Check the electrical connections coming out of the engine to the wiring harness. Just sitting in storage for a couple of yeas can cause corrosion on the contacts. Pull the connectors apart and clean them.
