I have many different things about the 080 and 115 belts. I am looking for the right belt to run I have a 07 dragon. I have read in some post that the 115 belt that is on the 07's is wearing a groove in the primary is this really happening, any info. would help. I don't really know why the 080 belt won't work they are on the older 700 and 800's. I have a 02 700 that I have done a lot to and never had a problem, so..... Is the 115 really worth running?
The Ultimax XS is a great belt. I have between 1200-1400 miles on one on my 2005 Fusion. It's the best belt I have used so far. I have the 3211111 but have not tried it yet. My sled is at the dealer right now getting the fuel float update and a 3211115 belt, which I probably won't run either. The Ultimax XS belt retails for $98.95 but, the last two I bought ran me around $77.00 each plus shipping. The Ultimax XS cross for a 3211080 is a XS409 and it carries a 1 year replacement warranty. If you blow in within the first year, they will replace it for a $10.00 shipping charge.
I have many different things about the 080 and 115 belts. I am looking for the right belt to run I have a 07 dragon. I have read in some post that the 115 belt that is on the 07's is wearing a groove in the primary is this really happening, any info. would help. I don't really know why the 080 belt won't work they are on the older 700 and 800's. I have a 02 700 that I have done a lot to and never had a problem, so..... Is the 115 really worth running?[/b]
The clutching was set up for use with 321 1115 belt on your 700 Dragon. Polaris put that belt on your sled. I would not be stampeded by rumors, you should use that belt unless you have a reason not to. It is a very well engineered and manufactured belt.
The clutching was set up for use with 321 1115 belt on your 700 Dragon. Polaris put that belt on your sled. I would not be stampeded by rumors, you should use that belt unless you have a reason not to. It is a very well engineered and manufactured belt.[/b]
That's good advice. I didn't know the 3211115 came on the 2007 Dragon and or some of the other 2007's. If someone is having trouble with the 3211080, 3211111, or 3211115 I would give the Ultimax XS #XS809 a try, as I have had excellent luck with it, as mentioned. Thanks again Excursion for all of the info you provide! Maybe we'll cross paths near Big Bay or on the way up to Copper Harbor?
