this is easy remove both the front and rear suspension bolts from the tunnel this will drop down the track and all. loosen track and pull out suspension. now do you have a cross country or 500cc because your dealer will need the adjustment knob to do the rebuild it has a quick coupler down by driven pulley watch the hose routing once you get the suspension out just remove the idler wheels and axles you need to nothing more keep track where everything goes when you put the undercarriage back in the front bolts go in first
the cams are not hard if you dont have a t-bar there hard just remove the lower slider block where the long leg goes in be careful its under tension be sure to mark where the upper pivot arm is on the shaft
