I'm running 23-40, 1 3/8 track, no studs, D&D kit. It may be too much this year as I am about 215lbs, and used to be about 195-200. (wife feeds me too good). Great top end and accelerates hard. what about you???
i'm running speedwerx TI kit, 22/41 gears, 9 tooth drivers and 1.7 inch track. i weigh 180 and am really looking forward to seeing how this setup will perform.
that combo rips for 1000 ft...from then on tho your not getting much more out of it....im trying that combo myself this year.
on nos it will be a ripper for sure.
<div align="right">index.php?act=findpost&pid=939978
what kind of top end are you getting MPH
I don't live by any lakes, but the last time I went to WI, I got 110 on the speedo. I don't even know what the stock gearing is on the 03 F7??What is it?? Since a lot of my riding in Iowa is ditches and short winding trails, I should probably gear down. Just seeing what everyone is running and how it works for them.
I think that you are probably running the best gear ratio right now.
I ran 22/41 last season (10T drivers, 1 3/8 track with 153 studs, I weighed approx. 225 lbs. with gear on). My sled pulled really strong up 85 mph or and then seemed to fall flat. Probably need to lean out the top rpm range a bit (clutching seemed to be good -- Simons CPR kit), but it seems like a higher gear would have helped. I plan on bulking up to 250 lbs. this winter though, so I think I may leave the gearing alone in my case -- lol!
