The weights cat calls for in the low elevation kit work good. That's what i've been running for the past 4 seasons.
0-3000 = 75 gr
3000-6000= 70 gr
6000-8000 = 68 gr
8000-11000 = 65.5 gr
I think that what cat recomends. With all the same springs and helix
Ya 75g sounds right with org/wht primary spring, d&d secondary spring and helix out of ext. Good inexpensive set-up.
Ya 75g sounds right with org/wht primary spring, d&d secondary spring and helix out of ext. Good inexpensive set-up.[/b]
Now what if i through a twist into it and asked what should I be running if I have an 800 big bore kit, speedwerx single, V-Force III's, and a boondocker??? Speedwerx is telling me to run 71.5 T2 weights, they say they react different (heavier) than stock weights??? Any input??? Sounds fishy to me. Thanx for the replies so far.
