41 - 60 of 99 Posts
Discussion Starter · #41 ·
EFFECTIVE March 7 2015 Water Pump rebuild Price needs to increase by a bit due to Polaris Parts Increase in cost
Old 2014 New 2015
3085286 BEARING, BALL 23.99 25.99
3085145 BALL BEARING 26.99 28.99
3085174 IMPELLER UNIT 53.99 56.99
3085269 SHAFT,WATER PUMP * 112.99 119.99
3085149 O-RING,(WATER PUMP SHAFT) 1.70 1.83
3085794 GASKET,PUMP CASING 1 2.04 2.20
3085270 BOLT 12.99 13.99
3085175 PLATE,SEALING 20.99 22.99
3085384 SEAL, MECHANICAL 40.99 43.99
3085271 GASKET, WATER PUMP 2.04 2.20
Basic Rebuild with return shipping will now be 158.00
Please keep message me before you send anything in, I need to be sure to schedule parts orders with incoming pumps
Discussion Starter · #43 ·
Braaaaapppppp Water pump time!!!
PM me and let me know you want one done to make sure I have parts in stock.
Prices are the same as when I posted in March 158$ back to you're door unless you need a impeller or gear/shaft
Roger
What's the procedure for rebuilding the pump? I've been able to find parts lists but not a whole lot of info on what to do to get it apart and get the new parts in. My '97 XCR600 is on 4500 miles and I don't know if the pump was ever rebuilt (traded an XLT for it last year). I also heard something about checking the weep hole for coolant to tell if it needs to be rebuilt, where is this located?
Thanks!
Discussion Starter · #45 ·
Pull it apart remove bearings and old seals clean up components press in new bearings and new mech seal use the other new internals as well and assemble use permatex grey case sealer on gear case side
Weep hole
The weep hole is at the bottom of the pump on the side facing the mag side of the engine. Don't wait for it to start dripping coolant to rebuild the pump. It's not there to indicate time to rebuild-it's there to show that a seal has already failed!
My pump went at 2300 miles, but high calendar time. The coolant got into the case, vaporized, and basically washed all the oil from the cylinder walls, scoring the mag and center pistons. Fortunately, the cylinder walls themselves were OK. Cost me a full engine rebuild, and of course the pump as well. The center crank bearings were notchy, too, but I can't say for certain that the coolant caused that, since the carb needles/seats leaked and I know fuel had gotten down there.
These are all well documented issues with XCR/Ultra triples. Some money spent up front on preventive maintenance pays big dividends in major repairs and grief avoided!:thumbsup:
I have mine all apart and cleaned up but waiting on parts. The bearing totally shit the bed. I know I have to put Loctite on the impeller bolt but do I have to put anything on the sealing surfaces of the mechanical seal? Ive heard to use a small amount of dish soap but I just want to be sure.
Discussion Starter · #48 ·
i use a light touch of grease dish soap like dawn would work also just some initial lubrication to give the seal plate and mech seal some seat time!
Discussion Starter · #49 ·
Water Pump Rebuild Parts are in if you need to get it done before the Slow Flies "being way late as it is"!!
Discussion Starter · #50 ·
Guys yet again Polaris Water Pump Prices have gone up, so cost of pump rebuilds will be increased by parts cost only. I am still using after market bearing @ 7.00 ea
3085149 O-RING,(WATER PUMP SHAFT) 1.99
3085794 GASKET,PUMP CASING 1 2.39
3085270 BOLT 14.99
3085175 PLATE,SEALING 23.99
3085384 SEAL, MECHANICAL 45.99
3085271 GASKET, WATER PUMP 2.39
3085174 IMPELLER UNIT 59.99
3085286 BEARING, BALL 26.99
3085145 BALLBEARING 29.99
3085269 SHAFT,WATER PUMP * 124.99
New Price with New assembly Hardware and US Postal Shipping is 163$ not including OEM Bearings Gear Shaft or Impeller
My pump shit the bed on the trail today. It's squirting from the bottom. Lots of steam in the exhaust. I assume that means it was getting in the motor? exactly 3500 miles.
Discussion Starter · #52 ·
Water Pump Parts have been ordered. message me before you send you're pump in
I moved and have a new Address
Price has remained the same
2 X AFTERMARKET BEARINGS
6001 $7.00
6002 $7.00
Stainless Assembly Screws / Washers 10$
3085270 BOLT 14.99
Pump Cases are also Bead Blasted to clean up the cases
add $35.00 for my Labor and 15$ for Shipping
Water Pump Rebuilds @ 165$ and returned
Roger, sent you a PM on a 96 Ultra pump. I need the ole girl fixed.:thumbsup:
Discussion Starter · #56 ·
hey roger , need to what signs there r for pump to wreck crank bearings
Crank Bearings?? or Water Pump Bearings??
Water Pump Bearings you can typically feel bad bearings by manually rolling the gear on the pump.
The Pump if bad can let coolant in to the crank case and sitting coolant on bearings is bad and can cause them to go bad.
But if caught in short time I would lubed down the crank and you could be all set
Crank Bearings is an inspection with a tear down.
41 - 60 of 99 Posts
