1 - 8 of 8 Posts
Can somebody tell me how i can go about chking my power valves and servo motor to make sure they are working correctly. My F7 sp is having a hard time breaking the 90 mph mark.
Thanks
Bob
take cover off servo run engine and look at motor you will see the spool rotate and the cables should move freely arund the spool then shut off engine and remove clip holding cables on spool slide cable off spool ,grab inner wire and pull and let snap back if feels stiff or binding take apart and clean allso at same time check cable lenght per owner,s manual
Originally posted by JLeosnow@Feb 10 2003, 06:33 AM
F7 APV valves do not cycle at start-up. RPM's must hit just about 7000 before you will see servo motor move....
-John
Thanks John! -- Roy
F5's do cycle once when first started. If you have a F5 and you hav'nt checked your APV cables do it asap-it makes a huge difference in performance.
1 - 8 of 8 Posts
