1 - 15 of 15 Posts
I know that this has been a topic in here before but i can't seem to find the answer to my question again.
My question is how are you guys fixing the problem of snow melting under the seat and running down the tunnel?
Thanks for the help!
you couldn't find an answer because no one has come up with a complete fix.
It's a tough one, but luckily tunnel ice will never leave you stranded ^_^ :p
Discussion Starter #3
Some guys were talking sealing the tunnel with caulk.
I really couldn't follow what they were trying to say.
thanks
Discussion Starter #6
Thanks f5sweden that is exactly what i was looking for.
tom f7
I don't think the above posted link fixes this problem, does it Rob??? Seems to me like it's probably coming from snow that's melting on TOP of the exposed rear heat exchanger between the seat and the tail light, which then flows under the seat and down the sides of the tunnel and the running boards??? That's my guess so far anyway! -- Roy
I think I may have found the answer. I am going to try it this weekend and will post pics if it does work
Rob, Ed found the answer it works great. still silicon in the same area as you did then take that thick silver duck tape and go over that. tested it out yesterday in Vermont. No more ice!!
GF7PE, please keep us posted. Our nice wide running boards don't do us much good if they're all iced up. Thanks! -- Roy
I've got 760 miles on and haven't noticed a problem. Are you guys riding alot of powder? Or maybe because I've been riding southern NH so more slower trails, rare to reach 75.
Here's my take. I had a very good seal around the exchanger but the rivits were not seal. So I used black RTV to seal the rivits and the big gap in the front. No need to remove the factory seal. Then you need to seal up the back of the seat. I run a strip of 1"x1/2" weather strip under the rear of the seat. Note the tunnel shape is not the same as the seat bottom and there are some very large gaps where snow can collect, melt, drain and ice up. I have done this and not tested it, but I am sure it will reduce some of the problem. Hope the sled does not need that snow to cool the big 700.
thanks i'll try the tape :)
as an update, I still get some ice, but nowhere near as much as I did before doing the fix.
1 - 15 of 15 Posts
