My F7 is lacking performance right now and was wondering what you guys thought.. The sled idles fine and drives okay at 1/4 throttle but when I give it and the rpm's start to climb it falls off and the rpm's get down to 4700 or so.. I have gotten my smart valve changed and compression is perfect at 145/145...My peak rpm is 7800-8000 but it falls off before I can reach it...Max top end is 69mph thru a flat open field...
Lacking performance.....? I'd say you have some mojor issues there. Have u had it to the dealership? What did they say? I would take it there and tell em i dont want it back until it performs right.
Just read the thread from snowblind "Power Valves Black Magics Veiw". That may be just yer problem, the power valves are sticking or the servo cables are disconnected...
RE-CHECK your smart valve,sounds like the white disc is restricting fuel flow
