Does anyone have the torque spec on the bolts in the rear skid? I want to check mine before I leave this weekend.
...as tight as you can get 'em with a 3/8" ratchet... B)
...as tight as you can get 'em with a 3/8" ratchet... B)[/quote]
But too tight is broke,I can break 3/8 bolts with a short 3/8 ratchet!If your still unsure drop a little locktight on the threads
I just glanced at my manual and all the bolt specs range from 20-30 ft lbs. torque
But too tight is broke,I can break 3/8 bolts with a short 3/8 ratchet!If your still unsure drop a little locktight on the threads[/quote]
must be a strong guy ;) I can't.
I should have said, as tight as you can get 'em COMFORTABLY with a 3/8" ratchet.
I rarely use a torquewrench. B)
