Just got my 08 Dragon 8 and wondering if anyone has any tips or tricks for these things? This will be my first Polaris.
Chris.
SLP vents, or similar, gotta get the heat out to keep the clutches cool. Lotsa info out there, search.
Start with the slp airhorn, flowrites, and replacement intake vents. Better profile clutch weights, 11 series, or hot seat hammerheads. Tighten throttle cable for a minimum of freeplay, .030" max, even tighter as long as when you turn the bars lock to lock the actual throttle position does not change. Check the oil pump setting once this is done.
