can i expect a gain in performance now that my t-body is opening all the way? i found that it was only opening a little more than 3/4 of the way
Depends, F7 or F5
I'm assuming F7 as you said throttle bodies...
The F7 goes by volts, certaing volt range at idle, certain range at WOT
Tightening the cable could cause these numbers to be off, meaning at WOT you could get more fuel than needed or less fuel. Ask your dealer to explain this as I kinda know how it works but not totally. Deals with how long the injectors stay open for, etc
Are you talking about F5's or 7's. See the one post in the other board(Firecat) on this site. The post is about throttle cables and carb slides.
I gotta a quick question since you guys are talkin about the throttle cable...I was readin up on it...and mine is really lose....and I was lookin at my machine today and I'm lost juss how and I suppose to tighten it up? if anyone can give me information on this that would be great...thanks... :)
