I noticed yesterday that where the throttle cable goes through the riser block it rubs slightly. No pics but if you follow the cable from the lever to where it enters the riser it should be clear. The side facing the back of the machine is not bad as it rests against the velcro for the handlebar pad, it's where the cable comes out the bottom and goes into the console. The edges of the riser block are kinda sharp on mine and it has started to cut the plastic coating. I simply put a 2" piece of black fuel line over this area, wrapped it in electrical tape and zip tied it to the braided brake line. Can barely tell it's there and it's better than having your throttle cable rub through. B)
