ate some of the aluminum away. I can only think it was easy off oven cleaner :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
who re-finishes clutch sheaves??
maybe I can get away with havin it cut.. but will probably need to buy a new 2ndary clutch!!! WTF :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
use a scotch brite pad , if there is anything you can feel after you buff it up then let us know how bad it is. Oven cleaner will change the surface of the clutches but I cant see it doing alot of damage.
better to replace the clutch,
oven cleaner,it you were to put a clucth in a vat of it over night,it would be GONE in the morning,nasty stuff on aluminum.
