I just heard that this procedure will get it running again. You need to locate and reverse the fuel pump leads. There is a connector just to the right of the steering right under the cowl. It is a polarized connector so you will need some sort of jumper wires to do this.
By reversing the leads to the pump you are causing it to spin
backwards and you are pushing fuel into the valves instead of into the
rail.
1. Reverse leads
2. Pull the engine over about 4 to 5 times.
3. switch leads back to normal
4. Pull the engine over and start engine.
The engine should start the first or second pull on step 4. as long as you
have sufficient fuel in the tank. If you look into the tank the valves have
to be covered with fuel or this won't work.
rail.
1. Reverse leads
