1 - 16 of 16 Posts
· Registered
Does anyone know if a Tempa Flow is good for/on a 2004 f5? i was thinking about getting one but i dont know if it will work good enough or not. thanks
aaron
· Registered
i thought tempa flow was supposed to be like the boondocker box for carb snowmobiles?
· Registered
tempa flow is for adjusting your jetting according to temp. they work great wouldnt see why it wouldnt work on ac there are a lot of people on hcs that have them most people say they work great.
· Registered
· Registered
Theres a guy in the classifieds on this forum that sells them for $150 i believe.
· Premium Member
Originally posted by racinfarmer@Sep 25 2005, 01:28 PM
It'll probably be louder, save a minimal (unnoticable) amout f weight, and like most others, lose horsepower.
<div align="right">index.php?act=findpost&pid=891695
Like was said before. The tempaflow adjust carb bowl pressure for varying temperatures. Once you have your carbs adjusted properly for the set temp. (-29c) then the tempaflow adjusts the bowl pressure so that you are always jetted right for different temps.
I had on on my ZR. Worked great. You will save fuel and maybe your engine!!!
But read the instructions before install, read again! And then get advise on here!!!
1 - 16 of 16 Posts
