Installed tank bag with map holder from arctic cat the way instructions said to, cant keep snaps on tunnel secure. Placed snaps as high as I could. Seems like its not big enough. Installed @ room temp as it said to. Not sure if I like this, or not. Anyone else install one of these with similar problem?
yes tight as hell....but it will go. push with you palm from the top and roll the snap on.
Ihave a snap that pops off every once in a while, a bitch to get back on.[/b]
Haven't had it happen yet, luckly. I know one thing, I'll never take the bag off.
You'll be happy with the bag though. The bag removal option is very nice
Dean,same thing happened to mine when I attempted to put it on,turns out I didn't put the snaps quite high enough when I drilled the holes,or the seams were sewed wierd,I didn't want to redrill new holes,so I took it in and had a sewing shop cut and insert a piece black nylon webbing 3/4 " wide on both sides. After the inside-sewing that she did it added only about 3/4" total length.Matches like factory,and no one has even noticed.10$,it was a last resort,and fits great!:wacko: ;)
