I could sit around and bitch about my dealer (has no update kits for any Firecats yet) the snow we don't have (we are far below normal levels in the mountains and every time it snows it rains on top of it) The poor quality oil the dealers try to force you to use.
I removed my exhaust pipe to inspect the cylinders and the piston face and they are coked on the piston near the ring belt and at the Y connector by the cylinders - if you spray with Amsoil power foam the pistons or the cylinders they clean up, but no way should the engine be coking in the first place, even with a premix still left inside the fuel tank.
It is time to change the oil to something better out there, Torco has been good to me in the past, so has Klotz - I even thought about Blue Marble oil not because of all the hype either, but I am a little nervous about using a oil that is not been tested by oil company for snowmobiles.
Has anybody used Blue Marble in there sleds and look inside they're engines ?
Other oils am looking at are Spector syn sno, Redline, Ipone what do you think?
