hey guys,
I broke one of the sway arm bushings that attaches to bulkhead. I see that it is riveted on, I understand I have to drill out the old ones but will a standard pop rivet gun work to install the new ones? any tricks or anything?
thanks
john
yes , a standard rivet gun will work, just be careful drilling them as not to spin them , they will heat up and melt the plastic, the rivets are 3/16, I'm sure you could use steel or aluminum, whatever you have , hope this helps, ron
yes , a standard rivet gun will work, just be careful drilling them as not to spin them , they will heat up and melt the plastic, the rivets are 3/16, I'm sure you could use steel or aluminum, whatever you have , hope this helps, ron[/b]
thanks for the quick reply
