ok suspension junkies i need some advice on this 600pro-x of mine.
for the past couple of years i have been trying to get this machine of mine to turn with confidence. i have tried USI px-301 skis and all it did was give me heavier steering and better turning in the sloppy snow.
the other day i was convinced that my rear shocks were pooched because i could push my rear of my sled down with great ease at the bumper even with my dials on 9!! i pulled my shocks and pushed them into the ground and found that they have tons of resistance, not to mention they get harder to push as i increased the numbers on the dials.
but i do notice that my rears suspension, while the sled is sitting on the concrete floor, is only touching the floor at the rear of the skid(about 10" of it). the front of the skid is sitting about 1.5" off of the ground.
this does not seem right to me. should it not be sitting flat on the floor for trail riding?? i do have my limiter straps pulled up to the 2nd hole but even when it was in the stock hole it stills sits off of the ground at the front.
i also noticed that when the sled was in the stock hole on the limiter straps, they seemed to be very tight and not loose like my friends pro-x.(they were a little limp when the sled was parked and his sled handles night and day better than mine)
so since i had the skid out i drilled one more hole above the stock hole and put the straps at that position. but i have not put my skid in as of tonight to see if this should work.
has anyone noticed this?? my friends xc sits flat on the floor and when i ride it is much more trailable than mine. not to mention it is lighter on the bars when steering.
any help or insight would be greatly received.
oh ya i am 205lbs with gear.
