1 - 10 of 10 Posts
Have a 02' zr 6 EFI cc and want to summerize it. I have done carbs before but never and EFI. How do I fog the motor or do I just run it once a month with stabilizer in the tank? Thanks in advance for your help!!
I've never fogged mine, others have. I just fill the tank,add stabilizer and start it once a month. At beginning of season siphon out the gas, never had problems.
I always add stabilizer to whatever gas is left in tank (Owner's manual says to fill tank) and run engine for a good 15-20 minutes to circulate through throttle bodies. Then I remove top of airbox and fog motor until it dies. Then I pour about an ounce of oil down each cylinder and pull motor over a few times. I drain gas tank in the fall and fill with fresh gas. I have never had a problem doing this.
I'm a start it and run it guy as well. I let mine run about 15 - 20 minutes. Spray cool water on the heat exchangers if your worried about it over heating.
I leave mine 1/4 full, but I also store it in my garage. It doesn't get too hot or cool in there. In the fall I top it off with fresh fuel and dump in a jug of injector cleaner.
Works good for me! :rolleyes:
wash, grease, run stabil through it, dump some motor oil in the cylinders, cover the underhood area with silcone spray.
I'd be interested in hearing what you guys do to keep mice out of your sleds over the summer. I have to store my sleds in a quonset that is prone to mice. I have been stuffing a rag into the exhaust to keep them out of there, but I found a mouse nest under the motor last fall. What works? Moth balls?
I'm a start it up kinda guy. Every week or two let it run for a couple of minuets or so. It keeps you in the mood for riding all summer and you get to smell the 2-stroke smoke. Oh Yeah Baby.
Bounce softner sheets have worked well for me with the mice problem. I store both of mine in a barn for the summer and have never had a problem with mice in the sleds. I just toss a few under the hood. Also, use steel wool in the exhaust pipes opening.
Bart ,
I Use Steel Wool In The Pipe . I Also Take Off My Airbox For The Summer 'cause It Makes A Good Nesting Spot For Critters . Toss Some Moth Balls Into The Engine Compartment And Into The Back Storage Box For Good Measure Too ! The Only Problems I've Ever Had Was Some Vermin Chewed A Couple Of Holes In My Cover. :angry: :angry:
1 - 10 of 10 Posts
