1 - 14 of 14 Posts
how will it wreck the hyfax if studs have a smooth head and sucked up in the track tight enough
the only place that I had an issue was up front at the bottom of the limiter strapthe track gets real tight there so I tightened them about one inch and seem ok. i only have about 220 miles on them but good so far
Discussion Starter · #7 ·
i also have had no problem i installed 136 1175 woodys and used closed window have only 120 miles all on a lake with no snow hyfax looks fine
540 miles on mine with 170 studs (studded in open window) the open window is the best place to stud. max traction under rails. 1.175 woodys megabites.I talked to the woodys rep and he said his f7 is studded in the open windows. Do it and you will be glad you did.
Has anyone tried more than 170 studs? My dealer has 187 in his F7 and is thinking about 204, this may cause a" bed of nails" affect. anyone???Snowhunter
1 - 14 of 14 Posts
