1 - 8 of 8 Posts
Had the new steering post put on and it hits even more with the new one installed. Anybody else had the same problem?
2014 XF800 137
I'm still in the same boat as you. Replaced steering post and still hits. Dealer just got 3 more and installed them in another sled and commented they were all bad. I finally took out bottom block which steering attaches to and put on a tach with the welder, this seems to work right now.
Banned
If you look at the service bulliten. It say's it may still hit the motor on a full turn right. How often are you going to do a full turn right? I will bet not very much.
Administrator
The real question is, how hard does it press against the cylinder? Mine touches, but it doesn't do anything to cause a problem.
Discussion Starter #6
mine pushes the mag side motor mount in about an 1/8". Long term damage is my concern.
Administrator
Then you've got a legitimate reason ... sorry to sound like I was doubting you Cajun. I've just heard a lot of people complaining, only to find out the steering post was causing no problems.
I found out from my dealer that AC parts dept was sending out the wrong part which was the bad one. They do have a new one but I did not hear how to tell them apart.
1 - 8 of 8 Posts
