does the 440 impeller push enough coolent to cool this motor on the trail. If not would one off an f7 fit?
I'd say call Speedwerx...., In their own brochure, it lists the 780 as not a good choice for trail use. Hopefully that just means it needs to be detuned with pump gas heads. Give them a shout, and then let us all know. Good luck!
there closed, but theres an email already sent.
<div align="right">index.php?act=findpost&pid=918180
zeppelin,
For whatever it's worth the 02-05 440 SnoPro is the same impeller as the 03-06 F7(part#3005-697) so the answer should be yes......
-John
Part Number: 3005-697
Fits:
Arctic Cat 2000 POWDER SPECIAL 600 EFI (S2000PSDEFUS-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 POWDER SPECIAL 600 EFI LE (BLACK) (S2000PSDELUSB-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 POWDER SPECIAL 600 EFI LE (GREEN) (S2000PSDELUSG-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 ZL 600 EFI (S2000ZLDCAUSB-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 ZR 440 Sno Pro (S2000ZRBPRUSG-2000) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2000 ZR 600 EFI (S2000ZRDEFUSG-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 ZR 600 EFI - LE (S2000ZRDELUSG-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 ZR 600 EFI - LE REVERSE (S2000ZRDENUSG-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2000 ZR 600 EFI INTERNATIONAL (S2000ZRDELOSG-2000) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001BCCWTUSL) (Bearcat Wide Track) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 (S2001MCCEFUSB) (Mountain Cat 500 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001MCDEFUSB) (Mountain Cat 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001MCHCAUSB) (Mountain Cat 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001PACCAUSG) (Panther 550) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 (S2001PSDAAUSS) (Mountain Cat 600 VEV) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001PTDEFUSL) (Pantera 580 EFI) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 (S2001TTDCAUSB) (Triple Touring 600) - WATER PUMP/MANIFOLD on-line parts
Arctic Cat 2001 (S2001ZLCERUST) (ZL 500 EFI esr) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZLDEFUSB) (ZL 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZLHERUSB) (ZL 800 esr) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRBPRUSG) (ZR 440 SNO PRO) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 (S2001ZRCCAUSG) (ZR 500) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRCEFUSG) (ZR 500 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRDAAUSG) (ZR 600 VEV) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRDCAUSG) (ZR 600) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRDEFUSG) (ZR 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZRHCAUSG) (ZR 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 (S2001ZTDCAUSB) (ZRT 600) - WATER PUMP/MANIFOLD on-line parts
Arctic Cat 2001 CROSS COUNTRY (S2001ZRBLEUSG) (ZR 440 SNO PRO) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 Illusion (S2001ZLHERUST) (ZL 800 esr) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001BCCWTOSL) (Bearcat Wide Track) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 International (S2001MCCEFOSB) (Mountain Cat 500 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001MCDEFOSB) (Mountain Cat 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001MCHLEOSG) (Mountain Cat 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001PACCAOSG) (Panther 550) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 International (S2001PTDEFOSL) (Pantera 580 EFI) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 International (S2001TTDCAOSB) (Triple Touring 600) - WATER PUMP/MANIFOLD on-line parts
Arctic Cat 2001 International (S2001ZRCCAOSG) (ZR 500) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001ZRDCAOSG) (ZR 600) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001ZRDELOSB) (ZR 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 International (S2001ZRHCAOSG) (ZR 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE (S2001ZRDLEUSB) (ZR 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE (S2001ZRHLEUSB) (ZR 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE (S2001ZTDLEUSG) (ZRT 600) - WATER PUMP/MANIFOLD on-line parts
Arctic Cat 2001 LE Black (S2001MCDELUSB) (Mountain Cat 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE Black (S2001MCHLEUSB) (Mountain Cat 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE Green (S2001MCDLEUSG) (Mountain Cat 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 LE Green (S2001MCHLEUSG) (Mountain Cat 800) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 esr (S2001ZLCDEUSB) (ZL 550) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2001 esr (S2001ZLDERUST) (ZL 600 EFI) - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2001 esr International (S2001ZLCEROSB) (ZL 550) - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2002 Bearcat Wide Track - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2002 Mountain Cat 500 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 Mountain Cat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 Mountain Cat 800 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 Mountain Cat 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 Pantera 550 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2002 Pantera 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 Pantera 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZL 500 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZL 550 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2002 ZL 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZL 800 EFI SS - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZL 800 EFI esr - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZR 440 Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZR 500 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR 500 CC - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR 500 LE - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR 600 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR 600 EFI CC - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2002 ZR 800 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZR 800 CC - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZR 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZR 800 EFI CC - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2002 ZRT 600 - WATER PUMP/MANIFOLD on-line parts
Arctic Cat ZL 600 EFI SS - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 440 Sno Pro L/C - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 Firecat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2003 Firecat 500 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2003 Firecat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 Firecat 700 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 Mountain Cat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 Mountain Cat 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 Mountain Cat 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 Mountain Cat 900 (Early Build) - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 Mountain Cat 900 1M - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 Pantera 550 - WATER PUMPIWATER MANIFOLD on-line parts
Arctic Cat 2003 Pantera 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 Pantera 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZL 550 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2003 ZL 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 ZL 600 EFI SS - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2003 ZL 800 EFI SS - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZL 800 EFI esr - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZR 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZR 800 EFI Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZR 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2003 ZR 900 Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 440 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 500 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 600 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Firecat 600 EFI Early Release - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Firecat 600 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Firecat 600 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 700 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Firecat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Firecat 700 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Firecat 700 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 King Cat 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 Mountain Cat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Mountain Cat 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 Mountain Cat 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 Mountain Cat 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 Pantera 550 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Pantera 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Pantera 800 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 Sabercat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Sabercat 500 LX - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Sabercat 600 LX - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2004 Sabercat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Sabercat 700 EFI EXT - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 Sabercat 700 EFI LX - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2004 ZR 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 ZR 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 ZR 900 EFI Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2004 ZR 900 Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 440 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 440 Sno Pro Modified Race Sled - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 Firecat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 Firecat 500 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 Firecat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 600 EFI EXT - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 600 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 600 EFI r - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 700 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 Firecat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 700 EFI EXT - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 700 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Firecat 700 EFI r - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 King Cat 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 Firecat 700 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 King Cat 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 King Cat 900 EFI EB - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 M5 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 M6 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 M7 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 M7 EFI LE - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Pantera 550 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2005 Pantera 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 600 EFI EXT - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 600 EFI LX - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 700 EFI EXT - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 Sabercat 700 EFI LX - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2005 ZR 900 - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 ZR 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 ZR 900 EFI Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 ZR 900 Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2005 Sabercat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2006 Crossfire 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Crossfire 700 EFI - West Yellowstone - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Crossfire 700 EFI EB - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 700 EFI r - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 M7 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 700 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 M7 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Sabercat 700 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Crossfire 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 500 - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2006 Firecat 500 Sno Pro - WATER PUMP/WATER MANIFOLD on-line parts
Arctic Cat 2006 Firecat 600 EFI - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 700 - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 700 Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 600 EFI r - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Firecat 600 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 ZR 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2006 ZR 900 EFI Sno Pro - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2006 Crossfire 600 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 Crossfire 700 EFI Sno Pro - WATER PUMP AND THERMOSTAT on-line parts
Arctic Cat 2006 King Cat 900 EFI - WATER PUMP/WATER MANIFOLD ASSEMBLY on-line parts
Arctic Cat 2006 Sabercat 500 EFI - WATER PUMP/WATER MANIFOLD on-line parts
