1 - 8 of 8 Posts
Finishing assembling my speedwerx 1000 engine and am wondering what i should use for clutching and gearing. Primarily am going to use the sled for 1000 ft races
Engine was originally a zr 800.
I'll be listening too. :div20: Twin pipes? Exhaust Valves?
Hey, you need to top that baby off with a Speedwerx Fat Daddy pipe! And it just so happens that I have one for the 1000cc for sale! :banana:
i've got the speedwerx twins, bored carbs, 2 degrees of timing, skidoo style exhaust valves. Goint to add extra cooler in rear and change needles in carbs and swithch out the boysen rad valves. I hear the rad valves block the rear boost port. Vforce3 is the way to go. Also switching the oil pump so the oil is injected into the carb boots instead of the fuel pump. I hear this makes them live!
Sounds like someone has been talking to a guy named Ron. :div20:
1 - 8 of 8 Posts
