1 - 2 of 2 Posts
I need to change out my speedo sensor on my 05 F7 efi. Only prob is I don't know how to do it, can anyone help me out with some directions?
Thanks in advance
Eddie
just did mine yesterday. first disconnect sensor from inside cab towards top of DD. there should be a little metal piece somewhat hiding it. jack up back of sled as high as u possibly can. sensor is located at bottom of DD in tunnel. There is a black screw type piece that u need to pull out. doesnt unscrew just pull. sensor should then slide off of case. feed sensor through hole in tunnel and take out from inside cab. hope that helps.
1 - 2 of 2 Posts
