1 - 9 of 9 Posts
I started my F6 the other day and it was ok than it started to sound a bit different and I noticed the rpms were lower than normal like around 1400 is this a sign of new spark plugs. It starts normal 2nd pull but I think I may need plugs cause why else would it be running at idle like that. I just haven't had the time to pull the plugs yet. Any suggestions.
hard starting, bogging or missing, or generally running like crap in any way is good reason to check the plugs on any 2-stroke.
sounds like it's time to pull them and give them a look.
So if I just change the plugs it should act normal.
mine ran great one day, started it up the next day and while idling I dropped a cylinder. Wasn't revving for shit. Changed the plugs, running on both again and going good :thumbsup:
try changing the plugs
I'll pull them out tomorrow and look at them hopefully they are just in need of being replaced.
Discussion Starter · #8 ·
Changed the plugs(what a hassle there not like changing plugs in a zr that im used too), but anyways started it back up and all seemed to be normal so by the looks of the plugs they looked good I guess I probably just loaded it up. Which means starting it less when it's sitting which may be difficult but im not changing plugs all the time.
i've found the easiest way to change the plugs on the Firepuss when at home is to just grab a nice long 13/16"wrench from the tool box, and reach in under the expansion chamber from the front.
nice for at home, but packing that wrench is not very trail friendly.
1 - 9 of 9 Posts
