I was just checking for a spare drive belt. Gates lists a 46R-4387 belt for $155.
Just a heads up:
This belt may not work as it doesn't appear to be as long as the OEM
3212325 belt. The 2325 belt at 45.51" outer circumference has approx. .35" longer outer circumference than the normal 3211215 NA 850 at 45.16". It also has face angles of only 26 degrees vs the OEM angles of 28 degrees. Furthermore, the Gates usually is about .020" wider inside the primary than the stock drivebelt.
In addition, Polaris has recently changed the OEM drivebelt to a new part number 3212348 which is supposedly .040-.045" narrower and 1/4" shorter. I wouldn't recommend using that belt. It may cause loss of acceleration and top end.
Just a heads up:
