Dealer sent pistons they were the right size but there was no room for the spacers on the crank shaft...it was smaller so the spacers didnt fit.... it shouldnt be a problem not putting any spacers right?
Do you mean the rod end? The spacers are more like thrust washers and need to be there. Do you have an after market piston? Remember to soak the bearing with oil before installing
Thats the ones with out them you will slowly grind away at the piston. Are you putting them in right? the ridges go toward the bearing
