1 - 2 of 2 Posts
can a F-7 sno pro be studded? My local dealer says they cant be studded due to track lug height and clkearence issues. Other dealers I have spoken with say you can using 1.45 woodies and following the template. what is the real deal
You can stud it. You have to follow the ribs under the tunnel. If you look in there you can see that over the center belt the tullel is higher in two places. You can NOT stud the outside belts or the center of the center belt. The 1.45 megabites are what you should use. Double backers are also good because they hold those long studs more rigid.
Cat S.
1 - 2 of 2 Posts
