1 - 15 of 15 Posts
I'm trying to upgrade my std suspension to the sno-pro suspension... as economically as possible.
I can't afford to buy new.
I called a few salvage places and they really don't have anything, they don't know the history of the machines the shocks came off of and have not been very much help.
Does anybody have a set of shocks to sell or know where I can get a set.
I was going to do the rear suspension first, then the front...as money permits.
I would consider trading for my shocks. My sled has 86 miles on it, so my shocks are still like new.
Any assistance would be appreciated.
its up to you, but if money is an issue you may want to send your shocks to someone and have them revalved similar to the Sno-pro shocks. The only thing you won't have is the resi's.
Thats what I did :div20:
If your on a budget you should have your shocks revalved, like the other posts said. That alone will make a huge difference.
I converted my 03 f7, bought Sno Pro springs front/rear. Sent shocks to Looneytune. Had rebuilt with heavier weight oil........ :cn:
I was thinking about re-valving exatly to sno-pro specs but I noticed the pistons in all the shocks have a different size bypass hole. Anybody else notice that? How much difference would the different hole make? Would it be worth buying the pistons if I did want sno-pro specs?
<div align="right">index.php?act=findpost&pid=866980
I have a set of sno pro shocks off an 04,$300
Denny
You could add reservoirs to your shocks, if you had to. Above deal looks good also. I can revalve to SP specs if you need to.
limiter straps are different lengths on the front arm, at least thast what the '05 standard VS a '03 sno pro is that are laying on my garage floor. also no spot to mount the resivor on the front arm on a standard.
1 - 15 of 15 Posts
