1 - 8 of 8 Posts
2014 XF800 137
Moving the front skid shock back one hole on the rails, will this give a better ride and more ski pressure?
I know Rob has tried this, but I don't remember his response on ski pressure.
My goal is to soften the ride on this beast, in turn gaining ski pressure.
Your responses would be appreciated. Thanks Les....
I tried it,I weigh 175 on a F5sp.Too soft and bottomed often.Tighten your limiter strap to the middle hole,that'll help with ski pressure.
When it bottomed did you tighten the spring blocks?
Fast 600 - let us know how it rides.
go faster! jk- though they do smooth out considerably at speed.
Is there anything other than fast??????? Untill you get stuck behind a slower group. Still love the sled!!!! :wub:
Moving the front shock back helps a ton with ski pressure, makes it better than a ZR. The trade off is that it makes the entire rear suspension softer, and the holeshot suffers, but these trade offs are slight, and well worth it in my opinion.
Do you guys just ride straight trails? Fast is great but sometimes not possible because of visibility through the turns.
I tried this, and it is not a good idea..
First of all, you need to put the limiter strap in the middle position or tighter, or else the shock will be limiting the travel of the front arm, (not a good idea for shock life).
Also, it makes the suspension WAY too soft, even for an old fart like me. Bottoms big time.
There are better ways to get the setup right.
1 - 8 of 8 Posts
