I just did a top end rebuild on an 06 firecat. Started it many times in the shop, got the coolant level all good, started many times, just sits there idles perfectly, starts first pull, thought the pto piston went down from crappy fuel, cleaned the tank all out lots of water and crap. Just scared of a possible crank seal or smart valve problem, I just can't wrap my head around a possible smart valve failure and burn down, shouldn't it just run out of fuel if the valve closes, 12,000 miles on this sled,I did a rebuild at 7000, just because. The mileage scares me about crank seal? Someone adjust my brain on the smart valve. I own five firecats and never an issue with that valve
